jonas_linder
Posts: 1587 Joined: Sun Sep 08, 2002 12:01 am
Post
by jonas_linder » Fri Mar 31, 2006 1:31 pm
Well its cast iron so the welds will not be pretty
But give it a go!
How does the turbo look without the flange ?
I may be able to make a new cadfile
nasse
Posts: 51 Joined: Wed Aug 20, 2003 4:53 am
Post
by nasse » Fri Mar 31, 2006 10:48 pm
Jonas. this is what the flange look like.
I heard that if you preheat the cast iron it wil be weldable quite nice.
any input on that?
jonas_linder
Post
by jonas_linder » Sat Apr 01, 2006 1:36 am
No comment on the heating part.. but jonasN said to me ones that if you weld on the castpart with the mig and then grind it down then there is no problem welding on it again
I think they have that flange at
www.klracing.se
Turbofläns ut
Garrett T03 med plan fläns mfl.
Bultavstånd 71mm
Priser:
8mm, 175 kr
10mm, 225 kr
8mm, Rostfritt 2343, 300 kr
nasse
Post
by nasse » Tue Apr 11, 2006 10:59 am
have done some moe work.
I had to reloate the wastegate because the stock location was to high to clear the body. it's pretty short but I think it will work.
here's the plenum. I know its not the ultimate design but l give it a try.
I have added some metal inside the plenum for the air in the runners to bounce against.
here's the plenum on the motor.
jonas n
Posts: 181 Joined: Sun Jul 03, 2005 3:32 am
Post
by jonas n » Tue Apr 11, 2006 1:24 pm
that´s a different design!
but very smart,you get the volume but saves the space...
Ephry73
Posts: 3369 Joined: Fri Mar 02, 2001 12:01 am
Post
by Ephry73 » Wed Apr 12, 2006 7:17 am
The design looks great! Good job man! Keep us posted.
E
Wally
Posts: 4564 Joined: Mon Oct 28, 2002 12:01 am
Post
by Wally » Wed Apr 12, 2006 11:39 am
Very nice design and very nice welding btw!
jonas n wrote: ,you get the volume but saves the space...
Why do you need plenum volume in a turbo motor in the first place?
Tnx,
Walter
jonas_linder
Post
by jonas_linder » Wed Apr 12, 2006 12:08 pm
Wally wrote: Very nice design and very nice welding btw!
Tnx,
Walter
You can get a boost in torque on a turbon engine too
nasse
Post
by nasse » Wed Apr 12, 2006 1:37 pm
thanks all for the feedback.
I'm going to do allot of minor things the next days. such as brackets for this and that........
you know, things that are quite timeconsuming.
I have also started on the fuelrails. I will post more pictures later......
krems
Posts: 211 Joined: Sun Aug 28, 2005 4:10 pm
Post
by krems » Mon May 08, 2006 12:06 am
really nice stuff....whats your overall budget?
nasse
Post
by nasse » Mon May 08, 2006 12:52 am
it's going to be close to $3000
witch is offcoarse the double of what I was going for
peumansjoris
Posts: 26 Joined: Fri Oct 14, 2005 1:08 pm
Post
by peumansjoris » Mon May 08, 2006 10:36 am
Nice setup !
Why did you put the turbo behind cylinder n° 3 instead of the otherside (n° 1) ?
Regards
Joris Peumans
nasse
Post
by nasse » Mon May 08, 2006 1:08 pm
peumansjoris wrote: Nice setup !
Regards
Joris Peumans
I tought it fitted nicely there
nasse
Post
by nasse » Mon May 08, 2006 1:16 pm
jonas_linder
Post
by jonas_linder » Mon May 08, 2006 1:52 pm
Very nice!
Why is it weld on the side of the flanges?
Intressting way of mounting the knockingsensor
I really like the way this engine is coming along! Nice work on the downpipe
But I have some suggestions for you
1. Get a bigger breather! That one wasn't even enough on a stock 2L type4 that I got in one of my cars.
2. Mount the temp sensor in one of the heads
Great work!
Will you be at any meets this summer ?
