Hot Wheels Build part 2
Hot Wheels
Hot Wheels
Final assembly is Finally underway. I freshened up the 002 trans I picked up for this project, all liberty gears, reverse had a bad tooth. I am ready to put the engine in today and start running fuel and brake hoses. The body is next door at the body shop getting final prep. I hope to have this thing pretty well done by the first of the year and dune ready for spring.
- Leatherneck
- Sneaks
Hot Wheels
Hot Wheels
Hopefully I will have some new pics to add today and over the next week. I finally got a little time in and got the roller back together for what should be the final time and the body is in primer this morning. Paint should be flying before the weekend! If i get the fuel, oil and brake lines run this week I could be setting the body on next week. Just ordered a mountain of aeroquip
last night to plumb the dry sump, coolers and fuel injection in. Thanks to muscle motorsports for used nascar fittings, saved 1/2 on fittings.
I also found in Speedway motors catalog some universal wilwood master cyls that come with large and small resiviors than can be top mounted or remote mounted. I have been working with girling 75a units but for $66 each i think these look like the answer i need.
http://www.speedwaymotors.com/pl/14,113 ... nders.html
Hot Wheels
- rickosuave1987
That looks great!
Baja
HookIt
SuaveRacing FaceBook
HookIt
- Getrdone
Hot Wheels
We started masking about 6pm and were done and cleared by 11. I have a couple friends that are really good with paint. Lots of pizza and beer... We bed linered the fenderwells and underside to keep the stones from tearing things up. I think we are going to liner the inside of the tub as well. Seems like a pretty low maintanance way to go.
Hot Wheels
Hot Wheels
Not the greatest pictures, trying out the wifes camera today... The chassis is just about ready, all the cooler and fuel lines are run. The wiring should be finished the first of the week, then cleaned up and wrapped,and then maybe i can finally set the body on. The engine pic is really of the dry sump tank i built, it has hinged baffles on either side of the pickup so when you are catywhumpas on i hill it keeps the oil flow near the pickup. Not my favorite place for it but in this very limited space project i could not find a better choice. If it ever appears to be a problem I will add an accusump to protect the motor but i think it will be fine. THIS MAY BE THE YEAR IT FINALLY SEES THE LIGHT OF DAY UNDER POWER! I guess its the upside to having to much time on my hands...
