Up to this point I have been severely hijacking Type4unleashed build thread, as his new Reichert Tuning lay-down fan housing prompted me to action.
What I have in mind will likely look a LOT like his, except without the 911 fan and alt.
Racer Chris has been using a similar Corvair-fanned setup with much success for some time, so I'll be trying to pick his brain for all I can get
The main reason _I_ am attempting this is for packaging in my 914: I want to put my dry sump tank down low, ~block level, and keep the lines as short as possible.
It's also likely I'll be able to stuff the GT17 in on the other side up front.
If it happens to look kickass and work better than stock cooling (it should) all the better.
To kick things off, I'll try and post 2 pics, one displaying why the Corvair fan needs cut down to ~9 inches, and one showing the initial mock up of the CB drysump install on a block.
Fan (unmodified, ~11" diameter) no optical illusion--it's touching the block:
Modified CB pump and manifold block for external oil pressure bypass. Pump is modified to NOT have the inter-stage passages, the stock output for the T4 oil filter comes off the scavenge pump. The 1/2" pipe port above it is for a Swagelock adjustable pressure relief, which will dump to the tank.
The passenger side motor mount is unmodified, drivers side needs an easily "doable" few mods.
EDIT: Much better description of the pump mods/pics in the drag racing forum, as well as explanation of using it as a "stage and a half" wet sump pump for 3/4 rocker box and/or turbo scavenging.
Edit2: Reattached images the bitworms ate
