Engine:
- Type 4 2.0 GA series engine, stock, has not been rebuilt, from a '73 914, using stock head gaskets
- CB performance dry sump oil pump with 8 litre oil tank
- 96 plate mesa cooler with oil T-stat
- FAT Performance 911 cooling system with custom directional vanes inside shroud for much improved air distribution
- CSP 1.5L breather box
- BAS 21152 header system slightly modified for turbo attachment
Intake / Fuel System:
- Custom intake system using 914 2.0 runner castings placing injectors in stock position
- 52mm Ford Taurus TB with IAC valve
- 4 x 40 Lb/hr (420 cc/min) Accel fuel injectors with custom bungs by www.vdubengineering.com
- MSD 43 GPH (2713 cc/min) HP fuel pump
- Carter 30 GPH (1893 cc/min) LP fuel pump
- MSD Boost sensitive fuel pressure regulator
- 1.0 L custom made surge tank
- 5/16" fuel feed line, stock return line to fuel filler neck
- 9/16" ID billet fuel rails with -6AN fittings
Electronics / Ignition:
- Megasquirt V2.2 board running MS&S - Extra
- FORD EDIS ignition system
- 8.5mm custom ignition wires
- Innovative LC-1 wideband O2 sensor and controller (not installed yet)
- Custom made 8 channel datalogger ( 4 CHT, 911 fan intake temp, ambient air temp, oil temp, rear wheel speed) Have wired up my VDO CHT gauge to this logger to show the highest CHT of the 4 cylinders, updated every second
Turbo system:
- TD04L-13T from a 2003 WRX (360-400 cfm @ 13.5 psi) stock
- PWR air to water barrel intercooler (4" x 6", 390 cfm rated to 270 hp)
- 2.25" piping from turbo to intercooler to TB
- Tilton differential/oil cooler scavenge pump to scavenge low mounted turbo
- Ford F150 Lightning intercooler water pump (not installed yet)
- Yamaha YZ125 radiator X 2 (not mounted yet)
- HKS SSQV BOV
Progress:
Everything is installed and wired up except for the LC-1 and water cooling system for the intercooler. I am just waiting for my ignition wires to come in before I can install them and perform a N/A start up and idle to make sure the MS is working. Hope to start engine in a week.
Next step is to weld up a 3" dia down pipe (not too difficult) and then install the LC-1. I am not sure about a muffler at this time as I don't think there is room for one !
Then install the YZ125 radiators and water pump for the intercooler
I am looking for about 160 - 180 fwhp for this summer (hope the motor stays together) and then will look at opening up the case winter 2006/2007 if anything needs attention.
Wish me luck !
These pics were taken about 3 weeks ago, engine bay is all tidy now.
Sandeep
