It has Ghia front brakes, and a setup in the rear I made back then using 914 discs and 411 front calipers. At this point, all calipers are sticky, and need to be gone through. I always thought the brakes very impressive for the car. It has a stock master cylinder. I used a line lock for a short term parking brake.
I plan just to stay with the Ghia front stuff. The question is will a 914 rear caliper bolt onto my 411 adapters in the rear? It would be nice to have cable parking brakes. Are the calipers the same bore size/pad size? I had the bias dialed in at the time.
Other question is I'm considering a Neal pedal set up, not sure what their master cylinder is made for.
Plan to run 235/60/14 tires back, 195/70/14 front T/As on 14x6 rims. Thanks!!
