parts in my engine
turbomike
parts in my engine
Post by turbomike »
i took off the bottom plate of mz empi deepsump.
there where three little pieces.
i looks like it was a washer. about 1inch outer diameter.
i was going to put my turbosystem on the motor. but i dont now i sould take the motor appart now. it a brandnew build 1776. i drove it for about 50 miles and motor runs good.
here are the pieces
http://mitglied.lycos.de/turbovwmike/000_0055.JPG
500LbGorilla
Post by 500LbGorilla »
Ewww.. looks like part of a lifter to me.
2332 baja
Post by 2332 baja »
500LbGorilla wrote:Ewww.. looks like part of a lifter to me.
I agree :shock: How thick are they?
Guest
Post by Guest »
about 3mm.
so wath exactly would that mean?
wath would i have to do?
i rebuild motors befor but never a bettle one.
VW_Dale
Re: parts in my engine
Post by VW_Dale »
turbomike wrote:i took off the bottom plate of mz empi deepsump.
here are the pieces
Check also for rockerarm washers that may have broken.
Bugfuel
Post by Bugfuel »
crank C-clip from the gear end?
Jan
mightymanx
Post by mightymanx »
spacer from the bottom of the distributor (dizzy) ? easy enough to check.
turbomike
Post by turbomike »
i checked everything out this morning.
dizzi and everything is fine.
it reallly looks like parts of a lifter!!
I have lots of tools but no vw special tools.
wath tools am i gonna need?
i would also like to buy a good book with all the specs on how to build the vw motor.
wath would you recommend??
turboblue
Post by turboblue »
here are the pieces
Looks like a pack of Marlboro Ulta Lights, boxed, to me......... :shock:
Oh the metal pieces, yeah looks like rocker arm spacers.
They go between the rockers and typically have the wavy springs between them.
Did you get some valvetrain noise before you stopped driving it?
Got a better picture?
Gary
Turbo VW Sand Drag Buggy
2013 Polaris Ranger 4x4
My Website
Shop Facebook Page
2332 baja
Post by 2332 baja »
Anonymous wrote:about 3mm.
3mm sounds too thick for any kind of spacer (dizzy, rocker arm, etc.) It almost has to be a lifter or the crank spacer. You could remove the heads & jugs to take a peek at the lifters,,, no special tools required. As far as books,,, I only have the good ol Haynes repair manual, How to Hot Rod a VW and How to rebuild a VW. I think the later 2 are available at CB Performance and the first can probably be found at a book store (Barnes & Noble or equiv) or an auto parts store.
turboblue
Post by turboblue »
3mm is .075" roughly. I've seen aftermarket rocker spacers that thick.
Maybe a head stud washer that somehow came off and got pounded and broken by the rocker arms. :shock:
Can't be a crank snap ring. Not large enough on the OD.
Looks too flat to be the head of a lifter to me.
Dizzy drive shims are not that large at the OD.
He did say about an inch or so.
Need something better than that crappy picture to determine exactly. :wink:
Gary
My Website
Shop Facebook Page
turbomike
Post by turbomike »
bingoo!!! :lol:
http://pg.photos.yahoo.com/ph/turbovwmi ... .dir=/aa8d
you guys where right!
now i just get new lifters and put it back togheter? wath could be the reason for such a failure?
turbomike
Post by turbomike »
oh my god!!! wath i the hell is that??!!
i have never seen somthin like that.
i just updated the photoalbum.
i cant believe that.
wath a crapie cam is that???
2332 baja
Post by 2332 baja »
WOW :shock: Can't believe that happened in 50 miles. Looks like it's time for a new cam & lifters. Who know's what happened,,, could have been a bad cam or lifters, or the wrong break in dance :wink: I would suggest CB's lightweight lifters. I have heard good things about them and I have them w/ a CB cam in my 2332. No obvious problems so far. I'll check em out when I tear down for upgrades this winter.
Guest
Post by Guest »
turbomike wrote:oh my god!!! wath i the hell is that??!!
Hey turdbowlmike...WTF DOES "wath" spell!!!!!!!!!!???????.
Do you mean "what"???? I know you do , but DAMN!!!
Once is expected, twice is understandable, everytime is freakin' unbelievable!!!!!!!....JESUSCHRRRRIST!!!
