Good discussion here.
I think the takeaway message is that accidents can be so different, that the devices that help the most in some cases can also hurt the most in others. The key being, you have to pick the options that can help the most with the least risks of hurting.
I looked up the Earnhardt thing again- it looks like there was a LOT of debate about the harness, and wether it failed or it was improperly installed. But it sounds like the final conclusion from the autopsy was that wether the one harness strap failed or not, he STILL had too much of a differential between the chest and head velocity. So if the harness DID in fact fail (or was improperly installed), he still would have died even if would have remained tight & secure.
I did some more reading, and found some interesting things about the harnesses and harness bars. It's all hit and miss, opinions and facts... but I learned a bit and drew some conclusions that I think make sense. I'll try to sumarize them here.
1) A 4-point harness can cause serious injuries in situations where a factory 3-point belt would be OK. The thing is, in an accident, your shoulders can rotate forward, pulling on the shoulder belts which will pull up on the lap belt. The lap belt then moves from your hips (where your body CAN support the load) to your stomach, where your internal organs are vulnerable. Because of the way that the 3-point anchors in the corner, pulling on the shoulder belt won't move the lap belt. For this reason, 4-point harnesses should be avoided, and either full 5 or 6 point harnesses should be used, or just the stock 3-point belt should be used.
2) A typical "harness bar", when a 4/5/6 point harness is attached, can be deadly in a rollover accident. The logic here is that a factory 3-point allows the upper body to move left to right, whereas a harness securely locates the upper body in an upright position. In a rollover without a cage (where the roof caves in), with a harness bar & harness only, the upper body is stuck upright, and it's your head & neck that must deal with the roof coming at you. With a stock 3-point belt, the whole upper body can move out of the way, greatly reducing the possibility of head/neck injures. Here's some example pictures. The driver and the passenger (instructor) in the BMW walked away without injuries. The driver of the CRX was banged up, but was OK. That's his helmet sticking out the window. In both of these cases, the occupants most likely would have died if they had been wearing a harness instead of the stock belts. (neither car had a roll bar or cage)
3) A harness bar can cause injuries in side impact collisions. What happens here- say we have two occupants, the driver and a passenger. An impact on the driver's side with stock belts would push the pillar in, creating excess slack in the driver's 3-point belt, and no change for the passenger. The same impact with the harnesses located on a harness bar could shift both upper belts, taking the head/neck/upper body of both occupants with them, and potentially tightening the harnesses to a point that could cause harm.
Soo.... this pretty much is a deal breaker for me. Even if you just use a plain bar to avoid the downward spinal compression (with no locating loops or anything else welded to the bar itself) with the harnesses attached to the rear, you still have problems. Yes, the side impact would now be OK, and yes, the frontal collision safety could be improved (positive: load distributed on both shoulders, negative: belt stretch), but it still wouldn't allow enough side to side movement to be of that much benefit. With the rearward mounting, it would have much more side to side freedom than one attached to the bar itself, but it still could only move so far. Only if the harness bar was an arc centered at the lap belt's level could it really rotate much side to side. If you're putting that much effort into it, you might as well build a cage.
After learning this stuff, I can't see how it would be a good idea.
(But, in the spirit of discussion, please chime in if you find something I was wrong on, or if you have other ideas!)
- David
