HPC Jet Hot turbo exhaust housing?
- panel
Can this be done? Is it recomended or better to leave it in its metal state? I'm assuming this will help alot with engine reduced temp if it can be done.
- Marty
I did mine and it works fine.
Here is a pic
[This message has been edited by Marty (edited 01-02-2002).]
Here is a pic
- panel
Well you can't get any better pic or car to prove it on than that! Thanks Marty!
- Steve C
Hi
My housing was done localy in black, I thought that silver was not suitable for turbo use. I would highly recomend doing it.
Steve C
Steve C
- Marty
I cant really prove the lower under hood temps but I did notice that the header (coated also) and turbo do cool down very fast. It is nice to be able to work on the motor after 5 minutes without leaving skin on everything reather then the 1/2 hour that it took to cool down before.
www.staggsracing.com
- panel
Should I go black OR silver on the housing?
- Muffler Mike
[QUOTE]Originally posted by Marty:
Here is a pic
did you have it done at Car Craft? if so what was there typical turn over time?
Here is a pic
newestone
I had my exhaust coated at Car Craft turn-
over was 5 days.
over was 5 days.
- Marty
Since Bob Godfrey at Car Craft is my pal, I can get stuff turned around real quick and I live near there so I take it to him myself. Face to face gets things prioritized a bit.
- Marty
Hey Mike,
Got my new suit for X Mas, got the pedals moved, got my phisical a few days ago and license passes start the 13th and Palmdirt. Track is open for time only. The 26th at the same track is a Super E/Super Comp race that I will be running at for the final few runs. I might even enter Super Comp (9.30 index up there).
