Since you seem to be the expert on the forum conserning plenum designs I am going to run mine by you and maybe you will be able to give some input.
Im running the cb end castings, similar to stock but with the injectors. Currently I have a t-section consisting of two 1-5/8" pipes merged into a 2.5" pipe that is about three inches long. Very little plenum volume.
What im working on now is a 3' pipe that ties the two endcastings together. The ends are about 1" long of 1-5/8, and the center, about 13.5" is 3"dia. Its designed to fit behind the fan shroud(non doghouse), by swaping the endcastings. I notched the 3" tubing around the fan shroud ring, and on the bottom side because of a case flange.
There will be about 10" of 2.25" pipe to the throttle body. The volume of the 3" and the 2.25" will be close to 2200cc. The 10" length can be adjusted to change the volume as needed. Since the runners are so short, about 1/3 a cylinder volume, how much bigger should the plenum be?
I tried to minimize the distance between the endcasting merge and the plenum to make it close to individual runners. Do you think that will have any effect? There is only about 2" length where the runners are confined to the 1-5/8 tubing.
The main question is how much bigger the plenum volume needs to be because of the short runners?
