Here is a loose translation according to:
http://world.altavista.com/tr
REMMELE of cylinder heads type 4
103 mm and 105 mm of drilling
Why?
VOLKSWAGEN stops already into the 80ern the production of the air-cooled penalty. The supply of parts thus meanwhile expressed problematic. New original Volkswagen cylinder heads are not available usually any longer.
Used heads nowadays already are since ten thousands kilometers in the use.
Cylinder heads for large volume engines starting from 2,4 ltr. must be extremely worked on. For this however perfect a starting point is necessary. Even then a service life, similar as attainable in the series, is never by the complex Umschweissen.
By the increased requirements of the beetle drivers the 2.4 ltr engine became meanwhile nearly the „Einstiegsmotor“. In order to be able to offer to our requirementful customers a stable engine, we developed our new cylinder heads.
Of course should be eliminated during this new development all disadvantages old type 4 of head.
The following modifications were made:
High-quality aluminum min transfusion.
Additional thermal treatment for increased material strength.
The angle of the inlet range was changed, thus the valve guide shrank over a length of 50 mm completely in the valve guide basic drilling. A loose valve guide, like with the worked on type 4 cylinder head is impossible thereby.
More largely before-poured inlet channels Ø 45 mm.
Generously arranged discharge opening channel. Cross sections to max. 46 mm are possible.
The spark plug position was optimized, kerzengewinde: M12 X1,25.
Against surcharge double ignition is possible.
Optimally CNC milled combustion chamber.
Improved valve seat material.
Changed valve guide position, thereby more place between the valves.
Special valves made of titanium or ceramic(s) are possible.
Heat sink increased clearly.
The associated intakes are usable for carburetors and butterfly valve parts up to Ø 54 mm.
To create the rocker arm range clearly increased over for all rocker arm translations place.
Newly arranged valve cover with O-ring seal.
Of course it is possible to equip existing type 4 engines with our new cylinder heads. A clear increase in output is guaranteed by us.
For further detailed information we are to you at any time gladly at the disposal.
TECHNICAL INFORMATION
Remmele of cylinder heads for type 4 engines:
Specially aluminum casting, later hardened, hardness: 110 Brinell
Intake with 3-Loch attachment
Valve cover from solid aluminum casting with O-ring seal
46 % more heat sink than series head
Combustion chamber back strengthens poured for 103 mm + 105 mm of drilling
Cylinder head within the rocker arm range more largely dimensions
Finishing cylinder head à CNC
Valve guides from high-strength bronze alloy
Special valve seats on the basis of newest criteria aerodynamically cleanly works on
Intake valve aerodynamically cleanly works on
Exhaust valve from Nimonic (easier than sodium-cooled valves, extremely good heat conductivity)
Valve springs: Single feathers/springs 107 kg, double feathers/springs for extreme engines 160 kg
Special aluminum valve retainer, coats, weight 8 gr.
Spark plug position optimally – against surcharge 2 candles per cylinder possible
Different inlet duct cross sections possible
Discharge opening channel generously dimensions
Exhaust attachment with 4 pins
Scope of supply:
2 cylinder heads
8 valves
8 valve springs
8 valve retainers
8 valve spring documents
2 suction tubes with ISO flanges
2 valve covers with O-ring seal
4 spark plugs (during double ignition: 8 St.)
8 tappet protective pipes
inclusive all screws, pins and u-disks
Blower box in GRP (against € 100 surcharge in carbon fiber)
Engine conclusion in carbon fiber
completely before-criticized
Â
Note:
When ordering the following Vorabinformationen is necessary:
Drilling/stroke
Ventilhub
Desired compression ratio
Prices for a pair Remmele of cylinder heads type 4
Standard version:
Duct cross section 45 mm (inlet channel)
Valve size maximally inlet 48 mm, discharge opening 42 mm
intake manifold Ø above up to 52 mm IDF distance for carburetors or injecting butterfly valves
1 spark plug per cylinder
Complete price: Â 3,990.00 €
