Throttle body sizing for turbo FI
Turbo_Rich
Post by Turbo_Rich »
Not sure if im posting this in the right area but anyway does any one have any suggestions about sizing a single throttle body for a 2459cc turbo FI engine? I picked up a TB the other day that is 65mm intake then tapers down to 55mm. Is this large enough?
tiethescore
Post by tiethescore »
Might be ok, might be a little small. Depending on the rest of your setup. There are alot of variables. If you build it with,lets say a ford mustang throttle body, they sale all kinds of sizes for it so you could upgrade easily without any modifications.
turbo_bob
Re: Throttle body sizing for turbo FI
Post by turbo_bob »
Turbo_Rich wrote:single throttle body for a 2459cc turbo FI engine? I picked up a TB the other day that is 65mm intake then tapers down to 55mm. Is this large enough?
In one word: Yes.
51 mm = 2.00", most turbos have a 2" compressor outlet, if your turbo has a larger outlet, size up the T/B and induction to match.
Guest
tb on you tpye 1
Post by Guest »
this will work fine where are you going to set your injectors and what ecu are you running
www.emeraldm3d.com
Guest
Post by Guest »
I am running a Garrett T3 and it looks like a 2" outlet which should be ok then. I will be plumbing it into a DTA P8 pro system which will have the injectors aiming at the back of the valves.
