Welded Rust --- what is it?
Posted: Tue Jul 05, 2005 8:06 am
Welded Rust....
This weeekend was welding some rust on a body-off car. I found a little rust underneath.... welded it... it pooled OK ... then did the surrounding metal... cracked it with a hammer and it seemed solid.
Is this OK to grind and paint...common sense says no...the other side says if it's solid and sealed then it should be OK.
T.
T.
