anyone have a haltech diagram?
i need the locations of the pins on the injector harness where it connects to the main harness? i know someone has the info, my haltech diagram only shows the ecu sid and nothing further. thanks. [email protected]
damn lazy peopleAnonymous wrote:e6swhats the link to the diagrams?
http://haltech.com/downloads/E6S.pdf
- Tom Notch
Was you harness a "flying lead" harness or completed by Haltech? If it has a plug on it for the injectors, the mating plug is identical in pin out and color code (IF supplied by Haltech).
If you are trying to finish a flying lead harness to fit your car, use your own pin out and what ever colors you can. That's what I do. On the one I just finished for my split, I used a 5 pin connector from the fuse block that was supplied on the flying lead harness from Haltech. While on my notch, there is no engine harness for the injectors as its all contained on the car body and the plugs just plug into the injectors.
The five pins are power and the 4 grounds from the injectors. The power wire is tied to 4 individual wires after the plug, one each going to the injectors.
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
Tom's Old VW Home
DVKK
