Talk to Dan at www.oceanstreetvideo.com
He runs the complete hide away CB blow through dual dell setup. He has some input that might make you think twice about blow through carbs.
Steven Arndt
hideaway turbo
kps73
hideaway turbo
I was wondering if the cb kit can be used with weber idf's ,I allready have em and dont want efi,cfi,etc pluse it saves a lot of money.I would like to no the good and the bad regarding this kit,I see alot of you suggest turbos from e-bay and home made exhaust for saving money.This sounds great to me and I have learned a lot just reading youre posts.Are there any books that I should get to answer and inform me further.thanks for your help.
Derrick from NC
hideaway turbo
Check with the folks from Competition Engineering http://www.ce-vw.com/ . They have a lot of experience with blow-thru carb turbo setups and may be able to modify the 40idfs. The problem with the 40's is they are built for a pressurized application and the throttle shafts will leak under boost.
Derrick from NC
hideaway turbo
Sorry....I mean not built for a pressurized application.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Derrick from NC:
Check with the folks from Competition Engineering http://www.ce-vw.com/ . They have a lot of experience with blow-thru carb turbo setups and may be able to modify the 40idfs. The problem with the 40's is they are built for a pressurized application and the throttle shafts will leak under boost. <HR></BLOCKQUOTE>
kps73
hideaway turbo
Thanks for the info guys.I am not going with the webers,expensive to convert,I still want a blow thrue system but will have to think about the price.pull through system sounds a lot easier,I will keep a close eye on the posts and get as much info as poss.thanks.
effvee
hideaway turbo
Webger carbs turbo converted: CB Performance has as of last year hade a conversion kit for the Weber. Also jayCee interprises "O" ringed my Dellorto shaft and can do the same to your Weber.
