Hi
My mate Leigh http://www.clubvw.org.au/leigh_harris.htm has done some testing on his water/air intercooler using some permanent temp senders.
He fitted a probe into his airfilter and one above the injector in the inlet manifold. After some testing he has found that he is only getting a 10° Celsius rise in temperature which shows how efficient the water/air intercooler is.
Regards Steve C
Water/air intercooler
What type of W-A intercooler did he use? Subary Liberty? I am planning on making my own out of a small ait to air core like is shown on Autospeed.com 's site.
Steve
Steve
- Steve C
Hi
His is custom made using an A/C core. He is also using a pretty highly rated water pump to keep it all flowing, I can get specs if you are interested. He is using a small motor cycle radaitor with a fan behind the rear wheel and a heater core at the front mounted on the axle beam. That Autospeed sight has some good stuff on it.
Regards Steve C
Regards Steve C
Of course autospeed rocks, it is from NSW!
Just like Aero guards, Steve Irwin, and Fosters.
Steve A.
[This message has been edited by Steve Arndt (edited 03-02-2001).]
Steve A.
