Hello to everyone on the site:
Can anyone tell me how much adapting you have to do to a Holley 4 barrel with vacum secondary 650 cfm. Thanks
Adapting holley carb.
There will need to be an adapter, like the ones sold by The Chassis Shop, to adapt the carb to the turbo inlet, and you will need to run a morse cable for the throttle.
As for the carb itself, the power valave will need to be referenced to the intake manifold past the intake. This is done to insure the power valve is open during boost.
good Luck,
RobT
good Luck,
RobT
