The Single-Relief Screamer Saga continues...
E100 Cam
Single Srings
Stock Crank, so, 5000-5500RPM
Solid Shafts
Swivel Feet (Ball-Style)
Do I need:
Heavy pushrods?
Dual-Thrust cam bearings?
I do plan on driving it pretty hard...
Thanks for your help,
Steve
Single-Relief 1641 Pt.2
Stock pushrods should be enough (with HD springs and the heavier adjusters they're nearing their limit but I'd give 'em a chance, if you find you're replacing them often you could get HD ones later).
Stock timing gears? You shouldn't need dual-thrusts, but they can't hurt anything. With straight-cuts they'd just be a waste of money.
