Hi Everyone,
This forum is heaven. I'm 90% sure i am going to use a beetle chassis for my home made kit.
QUESTION:
Is there ANY way of making a beetle MID-ENGINED rather than REAR?
I saw this pic after browsing for hours:
http://nova-international.net/data/chassis3n.jpg
It looks EXTREMELY mid engined. How?
Also, can someone finally tell me what kinda horsepower the standard '69 beetle engine can produce with minor modifications (ie: without reboring etc) or what type of engine i should go for. Yes I am one of those confused people that is considering a subaru conversion.
Thanx, this is good poop
[/url]
THE IMPOSSIBLE QUEST
cidarfritz
Re: THE IMPOSSIBLE QUEST
type "Nordstadt" into the search function button right on this page.
have fun reading!
Greetings
Stephan
have fun reading!
Greetings
Stephan
- Kubel Nick
Well, if you flip the tranny around and engineer a way to support the engine in the middle and add clearance to fit the engine. That's one way. THe way pictured at the link you posted, I personally wouldn't do as it looks like the engine's just sitting on top of the chassis. I'd at least cut into the chassis to allow the engine fit properly.X19Guy wrote:Hi Everyone,
[/url]
There's dozens of ways to do it. You can make a custom chassis instead of modifying a VW chassis too. Using a 914 chassis isn't the best route IMO as they require a portion of the body as part of the suspension (like fron front strut suspension of a Super Beetle). Not saying it won't work but alot of engineering to make it work still. You can buy a Porsche 550 kit car chassis.
Custom chassis work is not for the beginner, if you're serious I'd recommend buying one, getting someone to make you one or lear how to weld and fabricate well.
X19Guy
Thanx everyone for your info. I am a lot more educated now!
I'd ideally want a custom chassis from scratch, but until recently in Australia this was very hard and expensive to register. Im in the process of finding out about the new system the "VicRoads" have.
An existing chassis eliminates MANY problems with registraition.
As far as welding, I'm doing a course over the Australian summer.
I'd need to make a subframe to reinforce the bug chassis, so why not make it hold the engine too?
Thanx again guys
Thanx again guys
letterman7
You've got some help and direction on the Conversion thread as well as this thread. On my kit, I've got a mild built 1300 - it's got the 1600 cylinders, stainless valves, mild cam, lightened flywheel and dual Weber 40's. I've never dyno'd it, but my mechanic estimates it puts out around 90hp. Not a huge amount, but enough to get the car up and going in a hurry. I can even keep up with traffic here on our freeways, though overtaking someone at 70 might bring a challenge. And, the bonus is that I'm still turning 20-22mpg, and probably more after I do a tune-up this winter.
I've also been following PlasticFantastic on his EcoTec conversion. That holds a huge promise for a conversion in the future on my ride, but I've got to get a few bills paid, first!
Have fun!
Rick
Have fun!
Rick
Guest
What you saw in the picture was a VW transmission. You can have the same thing. Many shops make it possible to run them backwards by adding a gear inside.X19Guy wrote:Hi Everyone,
Thanx, this is good S**t
[/url]
'69 beetle produces about an honest 35 horsepower, or a dishonest 50 for a little while until it goes out of tune.
- dstar
Guest
check out vw off road mags or look online. there are manufactuers that make sand rail subframes that can be shipped knocked down. they can be set up to accept mid engine apps. i also think you can find a tranny rebuilder that can do the ring gear flip so's you can run mid engine. check out formula v racers they use it very successfully.good luck
