Hey whats up guys I want to know If I can use a bosch blue coil for my electronic ignition on my 009. Is there a certain one to look for? Any help would be appreciated
Does the engine have any extraordinary requirement for a "hot" spark (e.g. turbo or extremely high compression ratio?). If not the Blue Coil should be sufficient.
I recently purchased a bosch blue coil I believe is brazilian the part number is 9-224-771-008S. The coil itself is silver with a blue sticker that states super ignition coil without resistance. Would this certain coil be fine? No I do not run any turbo or anything that needs a hot spark.
