Subaru!! Who's with me?!?
- Hotrodvw
Yup....I bought a Subaru for my Baja. Anyone have any pointers, experiences?? It's an EJ22 (2.2L)
Eric
- 8WR_Buggy_of_Doom
- MNAirHead
Adapter---Kennedy Engineering sells the adapter plate --- call daddy because you'll need a loan or spare first child.
If you're patient, the plates can be found on ebay and/or samba every couple of months.
Bench Test the Engine---my parents are sold on the Subaru cars... the cars are sold after 80k when they develop a tick. They've never had a problem with the cars.
Advice -- start planning how you'll boost your frame horns... we took a friends rail out with the sub engine -- twisted the horns and roached the tranny in about 5 hours --- guess we were having too much fun.
- prerunner1499
- Jerry D
I will bet you, it is considerably more then 75 lbs heavier the the VW engine. We took off all the parts that were not needed from a friend's Subi motor then bolted it onto his EMPI IMP buggy. When we took the jack out the oilpan of the motor dropped down and sat on the ground. The fix for that was an expensive set of Sway A Way torsions.
Jerry...
Jerry...
alsehendo
Call Kennedy and tell them your converting a Vanagon they will send you their plans for wiring harness and other stuf for free. My 2.2 suby in my Legacy has 203K on it and it dose not burn a drop of oil or tick. I actualy bought it to convert my 80 Vanagon, but have been driving the car for 2 years without a repair since--can't bring my self to decommission it. The 4 wheel drive on freeway snow is awsome.
I've been keeping my eye out for a used Kenedy plate for along time and haven't seen one. WhenI do that old kingpin pan in the back may see some action, but the Suby engine may have 1/2 miillion miles by then.
- Hotrodvw
Brad
Hi Guys ...
Hey guys I am actually, as I type in the process of putting the finishing touches on our prototype buggy which is using our bolt in kit for the EJ22 Engine. We have managed to get about 80 mm of the sump and reverse the throttle body so it clears the back wall.
There are some pics here - http://www.netspot4u.com/~manxclub/gallery/album158
The engine itself weighs in about 5kg less than a type 4 engine with upright kit on it. The EJ 22 completely dressed with oil and water weights in at 115 kg the type 4 came in at 120 kg and a type 1 at 80 kg.
It is a great conversion and now we have ground clearance back it is even better. Fitting up the hotdog tommorrow and then we will fire her up for a test run.
Cheers,
Cheers,
