Cool tin fitting
bajaua
Cool tin fitting
Post by bajaua »
Hello,
Can any one tell me how to put the cool tin on? because i got mine and tried to put them on my engine but did not fit.
i mean are there steps, like removing head and pushrods tube or...........
Thanks guys
Later.
Glenn
Post by Glenn »
The Type 3 "Cool Tin" has to be put on before the head and pushrods are installed.
You can't add them without taking the head off.
bajaua
Post by bajaua »
Hi :) ,
is worth it to pull the heads off and istall them since this a new engine and yesterday was the first start for the engine 8) , the engine still on the table :roll: .
thanks. :wink:
Glenn
Post by Glenn »
You need either the T3 "Cool Tin" or the stock Type 1 deflectors.
If you don't have either, then i'd do it.
Post by MASSIVE TYPE IV »
Just tested it yesterday! 6 hours worth of testing!
engine ran 18 degrees hotter on the left bank, and 25 degrees hotter on the right bank immediately after it was installed. I tested it back to back with my DTM and the stock system and both results were the same. It also pulled 3 more HP from the engine.
Its hype, I always thought so... The dyno don't lie! I will be posting the spreadsheets as sooon as they are analyzed.
Glenn
Post by Glenn »
Jake,
You saying the engine ran 18 degrees hotter with the Type 3 Cool Tin than the Type 1 deflectors?
bajaua
Post by bajaua »
mmmmmmmmmmmmmmmmmmmmmmm
one more reason not to pull the heads off
Later 8) [/quote]
kafer-cup
Post by kafer-cup »
Please explain Jake, is what Glenn is saying correct??
Mark
VW_Factor
Post by VW_Factor »
Yes.. Indeed. What exactly was it that you tested Jake.. :?
The cool tin?? Type 1 deflectors?? A DTM with cool tins?? *shrugs*
Nope, the STOCK TINS ran cooler than the "Cool tins"
Glenn
Post by Glenn »
Jake... Thanks for setting the record straight. There's nothing like real world testing to prove what works and what doesn't.
bajaua
Post by bajaua »
Good job Jake
Thanks 8)
