Jake/Anybody, i was wondering what code engine case you use to build your type 4 engines or if they are pretty much equal.
Thanks.
Type 4 Engine cases?
- dstar5000
GRab a case, hopefully it will be a good one, do the usual checks.
If it looks like a gorilla used a pry bar to open the case, find another one....
IF you want to run carbs and a electric fuel pump(cheaper!), then your best off with
a 2.0L case, as the fuel pump boss/mount hasn't been drilled.
Good Luck!
Don
Good Luck!
Don
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
- Mr. Electric Wizard
- dstar5000
Read this thread!Mr. Electric Wizard wrote:So, what if it has been drilled?
http://www.shoptalkforums.com/viewtopic.php?t=62819
Don
