Heads, how much would you spend?
Posted: Tue Nov 04, 2003 5:32 pm
This poll will dictate what happens with the design of the heads that we are working on. I urge everyone that is a TIV enthusiast and reads this post to please vote and let us know how much you would spend.
Keep in mind that currently a set of fully ported and polished heads for a TIVrun around 1K bucks by the time you are finished rebuilding a set of 25+ year old heads.....
The heads will have a TI exhaust port but will retain the TIV intake port, it flows like a monster anyway and will stay compatible with the current manifolds on the market. That saves money. The heads will closely resemble a stock TIV head and will have as many fins as possible around the exhaust ports. A TI style merged header would work almost effortlessly as long as it has slip joints to aid in the install.
Heads would have basically any size valves anyone could want up to 50x40, and maybe even bigger. Big valves won't be needed near as much with a better flow characteristic, especially for engines that won't be super low torquers.
This will change all the engine combinations and as soon as these heads are finished I'll be building engines left and right with cam changes to see what the heads like. Chances are more cams with TI characteristics would work with these heads like a charm.....Split duration might just end up with a plus on the intake size instead of the exhaust like we use now for std heads..
My goal with these heads:
Run cool, keep the finnage as much as possible
Increase exhaust port flow
keep them compatible with current cooling systems
make them compatible with TI larger diameter heater boxes
keep them using TIV rocker assembliesand valve covers(for cost reasons)
Above all make them A BOLT ON!!! These heads will come into the states only as barecastings and will get CNC port work, the correct guide and seat material, and severe duty valves with 8mm or smaller stems for custom orders.....
So, now go vote and tell me the maximum you would pay for a set of heads that will unleash atleast 75HP more from any current combination that I currently build. Don't be stingy!
Remember the persons working with me on this are watching these threads. If we don't have the demand they won't make the supply with my assistance. I'm willing to be the guinea pig, supply the test engines(mostly built from used parts) give the time and the enthusiasm to make this happen.
All I need is support and comments. If you have ANY QUESTIONS ask them in this thread!
