Any thoughts on roof gutter surface rust (no holes).I have a 76 Westy with original paint which is still in overall good conditon, want to get this fixed asap.
Interested to hear what others have done to address this.
Rain gutter suface rust in 76Westy
- NO_H2O
I used a 90 grinder(air) and some Scotch Bright dics(fit small sanding arbor). Use the edge of the dics and removed the rust and old seam sealer, then re-sealed with seam sealer. Then prime and paint. you will only remove a narrow path and it will be out of site so you should be able to use a brush to prime and paint the area that was repaired with out painting to whole roof. If you don't all the rust and old sealer out and re-seal the rust will come back.
