oval front window measurement
Posted: Fri Jul 11, 2003 2:42 pm
by snoshrd420
i need someone to measure the front window from where the bottom of the lip where the cowl and dash are spotwelded together to the top where the rubber seals up i need the measurement taken in about the middle between the wiper shaft holes ,obviously this would have to be measured off someones project that has no window installed anyway if someone could do this it would be greatly appreciated i am installing a new front clip from window pillars foward cut a little above the upper heater vent ducts at A pillars and i want to make sure it fits correctly also if u have any tips please feel free to share them thnx
Posted: Fri Jul 11, 2003 10:10 pm
by hillbilly
:D What year is your bus?.......I will look and see if I got spec.s for the front window opening.They will give you all the measurements you will need. If possible provide me with a fax # as it would be easier to send to you (I can load into my comp. but will take longer to do,as i am not 100%sure on how it works yet :lol: ).......... :oops:
Posted: Fri Jul 11, 2003 10:24 pm
by snoshrd420
actually its for a 1956 oval bug i just need the vertical measurement
Posted: Fri Jul 11, 2003 11:17 pm
by hillbilly
:oops: why did assume a bus :?: I was thinking newer too :cry: doubt if I will have anything that old but will look around for some info. :?
Posted: Sat Jul 12, 2003 7:45 pm
by snoshrd420
cmon guys someone has to have a oval shell around with no front windshield to get the measurement?
Posted: Sat Jul 12, 2003 8:18 pm
by hillbilly
You can go the long route and pre fit everything inc the w/s would be alot more work but doable :cry: will look into some old books at work and see what I can dig up. :wink:
Posted: Tue Jul 22, 2003 9:29 pm
by Volkswagen147
i am putting my windshield in my oval on thursday but will get the measurement for you tomorrow and post it.
