how to help paint dry faster???
Hi I was wondering if anyone had any tips on how to make paint dry faster. I used some spray can primer and it is taking a while to dry. I have tryed heating it with a infared heat lamp I have but it didn't really dry it. Any advice?
- JC-ATL
Lots of heat and air circulation will help flash times, but we're talking more heat than you're gonna get from one heat lamp. Too much heat will screw it up, too.
Too much air circulation can be a problem as well, as if you start circulating air, you're bound to circulate particulates.
Basically, be patient - it will dry eventually.
japan drier
I've seen in the hardware store a product called: JAPAN DRIER, it is suppose to help speed up drying paint. Would this work on spray can primer?
- Kubel Nick
Also you may be putting too thick of a coat. Better to put multiple thin coats then a heavy thick coat. Should speed up the drying process as well.
Also what type of infrared lamp were you using. If it's the one used for tanning or for plants, that's not the same types used in professioanl paint shops. Paint shops can get pretty hot to cure the paint faster. Use more heat lamps if it's a small one.
- vw ninja
paint dry?
i suggest heating the paint up with a blow torch or waiting until the earth is closer to the sun then trying again
- Fusillade
