How long does it take for POR15 to harden and cure?
VW's aircooled mini SUV. Great for riding in the country, or cruising the beach.
peterjager
Post by peterjager »
Paint the pan today, but how long does it take to harden and cure?
Peter
Thingguy
Depends
Post by Thingguy »
Depends on the humidity, temperature, ventilation & how thick the coat is. Probably within 24 hours though. That is always when I apply the 2nd coat.
Scott
peterjager
POR15
I put it on a thicker coat, maybe that is why its taking longer to dry.
Hope it dries with in 24-48 hours.
Temp is 90's
Humidity is very low here in the desert in Texas
Ventilation is good
Peter
Thingguy
painting over por-15
Post by Thingguy »
If you plan on painting over it I recommend applying some primer while it is still tacky.
Glenn
Post by Glenn »
It's best to put 2 thin coats than 1 thick coat.
peterjager
It's hardening now, but still a little tacky
I already did the thick coat, so its to late now.
I hope that it dries by thursday?
Peter
Thingguy
drying
Post by Thingguy »
I imagine you will be OK. Put a fan in the area.
