Drilling and tapping the case Q
purple69
Post by purple69 »
i just got my case back from the machine shop and i am about to start assembling my engine.......but i want to drill and tap the oil gallerys first.
i went to home depot today to find some plugs but i had no luck. where is a good place to find some plugs like these:
fredybear
Post by fredybear »
U can buy the brass ones at
mscdirect.com
the aluminum ones u can get from an aircraft parts dealer i think...
wchiro
Post by wchiro »
If you know anyplace that sells Scat products, Scat has a kit of aluminum pipe plugs for the engine case. Aluminum plugs are prefered over brass or steel due to the different expansion rates.
Aloha from Hawaii,
Wayne 8)
BenI
Post by BenI »
RT
Post by RT »
I just bought some. Blue anodised aluminum as pictured. Only I used 5 1/8" NPT as the local store couldn't get stock on the 1/16NPT ones. Any decent parts store that deals with Earls, Aeroquip, or Goodridge should be able to get them. Here's some links;
http://www.goodridge.net/maincat2002/SECTION7.pdf
http://www.amstreetrod.com/html/capsplugs.html#npt
http://www.bakerprecision.com/adapt6.htm
Scott H
Post by Scott H »
Summit Racing also has the aluminum plugs:
http://summitracing.com/
They have all four sizes.
BugMan - 74
Post by BugMan - 74 »
As mentioned here and in my article, http://www.summitracing.com is one place you can find the plugs online. Any local "high performance" shop that carries fittings should have them also. The 1/16" NPT tap is the hardest to find, but its the proper size to use. You can order them online from http://www.mcmaster.com/ or http://www.e-taps.com/
bartman
Post by bartman »
i did my case with scat's plug kit pn 50033. it includes 5 each 1/8", 2 each 1/4", and 3 each 3/8". no 1/16" and it plugged every factory plug
