What radiators are you guys using?
- miller
Im gonna go to the JY pretty soon and I wanna get an idea of what radiators can be fit into the front of a bug/ghia. Oh and how are you guys cooling the radiators. Fan? Ducts? Thanks
- miller
Maybe- if I were you I'd go to a junkyard and check out a Turbo T-bird
or similar car. See how big and thick the stock radiator is.
Cooling a rotary is said to be harder than a piston engine,so this radiator
might be ok for your 2.3 .
There's a fellow on here=Blind Chicken Racing ?-that uses a Turbo 2.3 in
his baja.
Check some former posts ,he's got a website. See what he's using for
a radiator.
his baja.
a radiator.
I'm using a custom, 3 row core radiator that has tapered headers on the side to get the most surface area.
I fitted a 16 inch 2340 CFM electric fan to it and I am busy making an airdam with duct that will really force air through the radiator.
The duct is about 2 feet wide and 8 inches high so there is going to be a gale force wind howling through it which will keep the 3000 cc V6 in the back nice and cool.
I'll post some pics once I get it finished (which will be a while).
Paul
Paul
- zenjoe
