adjusting valves
nsargeant
adjusting valves
Post by nsargeant »
allright, i tried to adjust my valves for the first time and I turnd the flywheel to TDC and and adjusted the intake and exaust valve for the # 1 cylinder and I rotated the flywheel 180 and adjusted the intake valve for the #2 cylinder and then went to the exaust valve and it was really tight. like it wasn;t in the firing position. this may be a bumb question but do i have to rotate the engine another 180 degrees and adjust it? thanks nathan
amskeptic
Re: adjusting valves
Post by amskeptic »
nsargeant wrote:allright, i tried to adjust my valves for the first time and I turnd the flywheel to TDC and and adjusted the intake and exaust valve for the # 1 cylinder and I rotated the flywheel 180 and adjusted the intake valve for the #2 cylinder and then went to the exaust valve and it was really tight. like it wasn;t in the firing position. this may be a bumb question but do i have to rotate the engine another 180 degrees and adjust it? thanks nathan
When you adjust your valves 1 then 2 then 3 then 4, you have to rotate the engine counterclockwise 180* each time.
Colin
captCRUNCH
Post by captCRUNCH »
and if you are turning your engine clockwise (nomal running direction) its 1-4-3-2.
KaferK
Post by KaferK »
Colin
The first time I ever adjusted my valves I went clockwise and ran into the same issue. It's bewildering and you think that theres something wrong, but... you just turned it the wrong way! lol.
