Sealing shock through the fenderwell
- usabug
Anyone have any good ways to seal water and debris from the hole in the fenderwell where the shock goes. I mounted the shocks to the roll cage inside the car, and I want to seal the area to help keep out water and dirt.
Pictures would be good too.
Dean
Dean
- Hotrodvw
I was told by Prerunner1499 that inner tube material works well. Cut the hole smaller than the size of the shock body, so that the material is a stretch fit to seal. Use a narrow strip of aluminum to make a flange border around the hole that you cut, and pop rivet it, or screw it to the fender well. Good luck! Eric
Eric
- findog78
The actuater rod boots off a CH46 rotorhead work perfectly. They are made of a thick yellow "life raft" type of material, with a zipper slit and velcro sewed around the top to wrap the shock. The bottom was fastened to the fender well with a metal ring I cut out like a shifter boot has. Wish I had some more. Im sure a tailor could knock a couple out.
- CopperBaja
- Kraut_n_Rice
- CopperBaja
- Kraut_n_Rice
- 57baja
It's a poor picture, it actually looks a little better now with some dirt on it. I cut the sleeves and shoulder area out of a child size wet suit and riveted it to the fenderwell, along with some Sikaflex to seal it. It works BITCHIN! It keeps the dirt out, and actually cuts the noise down, too! Yes, it works on coil-overs, as you can see.
- Kraut_n_Rice
- takotruckin
- CopperBaja
