Adapter Plates, Who uses them?
Flipper
I have a set on the rear of my rail and somehow sheared off the drivers side Sunday afternoon riding around. Wasn't hot rodding it because I had my son in the car with me. How often does this occur, as I have been told that this happens alot with adapters?
Flipper
Flipper
type34sunroof
Quality adapters/spacers should work fine. The Porsche people use them alot to put late wheels on early cars. Problem is the ones sold off the shelf for around $40 a pair for V-dubs don't even belong in a cracker jack box, much less on your car. A good set is gonna cost alot more than just using the correct pattern wheel or drilling your drums/hubs to the correct pattern. Better SAFE then sorry.Right?
- prerunner1499
I bought mine from wolfgang out of hot vdubs. 69.95 a set, 5/112- 5/205
they are 1/2 " thick steel. They came in 3 days. I drilled them and pressed studs in. I really doubt they will ever break, as these things are buff stuff.
The ones I see and hear of braking are those cheap a$$ pot metal cast jobbies. Man ,,, a good fart across those and they will crack.
- usabug
