Smog pump is it ok too...........
Posted: Sun Jul 28, 2002 3:05 pm
by luckys420
is it ok to remove the smog pump from my '73 bus? do I need new heads if i do this? i dont need to pass smog any more and it is always in the way while making adjustments.
later
lc
Posted: Sun Jul 28, 2002 6:20 pm
by Pillow
You just need to plug the air injection holes somehow.
If the engine is out you can use 8 or 10mm (cannot remember which) valve adjusting screws in them. Otherwise I think a custom welder might have to shut the tubes up somehow.
Adrian Pillow
'66 VW Westfalia - "Biscuit"
'67 VW Deluxe Westfakia - "Dino" - FS
'79 Porsche 911 SC - "Cochese" - FS
Posted: Sun Jul 28, 2002 7:39 pm
by luckys420
thanks pillow, i'll just leave it on for now.
later
lc
Posted: Mon Jul 29, 2002 5:08 am
by Brett Anderson
Whats the approximate value of smog equipment?
I have a pump(fairly new) and a tube set from a 914 that is sitting in by barn.
Posted: Wed Jul 31, 2002 9:33 am
by Dave_Darling
A pump that is not frozen, and a pulley that is intact, are worth some money to CA 75-76 2.0 owners. They have to have a working pump to pass smog...
Dunno exactly how much, though.
--DD
Posted: Wed Jul 31, 2002 1:06 pm
by Thumposaurus
it better be, my '73 when I got it had the holes plugged with some bolts threaded into them I had one come out once, I thought I had broken something, it sounded really bad, I put it back in with loctite, and took the rest out and re-loctited them and haven't had a problem since.
Posted: Wed Jul 31, 2002 11:59 pm
Oddly I had to figure this out many moons ago...(REAL bad popping noise on a bus I picked up free, still running the shortblock ~10 years later)
Threaded "lamp" tubing is exactly the right size.
This is the ~6" long all thread tube they use to put lamps together. (the ones with shades, on your coffee table, comes with thin nuts, may be usable)
Any hardware store has these, and they are amazingly inexpensive,
Crimp the ends, put some burrs on the thread and some high temp (muffler) goo, and you got it for ~ $6.
Just be careful how far you screw them in--- they can hit the valves.
