Type 1 sotck EFI from Mexico ..injector size
Ephry73
Post by Ephry73 »
Looking for Injector size for a 1776 engine.
and other changes to make it more enjoyable and driveable....
CR is about 8.5:1
Cam will be a Web 119 or alike
The TB is about 36mm at the throat, runners are about 1.5 ID
Heads are 041's ported and partially polished, unshrouded valves( 39ins 32 ex's)
Ignition is Unilite Mallory
Flywheel is stock weight
1 3/8's header
Any suggestions? redline l'm hoping for 4600 or the like
Shad Laws
Post by Shad Laws »
Hello-
Rough rule-of-thumb for injectors: 1 lb/hr is good for 2 hp.
On my ~220hp engine, I have a 30 lb/hr injector on each cylinder. According to my computer, the maximum duty I've hit with them is about 90-95%, so the math seems to work out well :-).
Take care,
Shad Laws
LN Engineering
http://www.lnengineering.com
Ephry73
Post by Ephry73 »
Ok, thanks... Appreciate all the help....
Ephry73
Post by Ephry73 »
Shad, now that I know I have to resort to Hydrolic lifters to use the Mexico EFI, what type 1 conversions do you know of or recommend?(Jake or John any help please)
I want to make sure that the 1,776 engine is both reliable and "peppy"... I figure I could get 13lbs/Hr injectors and that would get me to what I want out of the engine, and if I stick to the EFI from say a VW Fox, or a Rabbit of the same size engine I would be more or less in the field. What items am I missing from a setup for type 1?
