I found a kit in my local electrical shop for $40 with a digital readout. It says that it works with a Zirconia (I think)EGO.
Heres the link : http://www.dse.co.nz/cgi-bin/dse.storef ... View/K4213
Remember the price is nz$. Any comments on this ? Theres also a high energy ignition kit in here : http://www.dse.co.nz/cgi-bin/dse.storef ... View/K3303
What is this?, Hopefully someone can help me here
Air fuel meter
Air fuel meter
It will work with about any sensor, heated or not, that you choose. Only expensive sensors will not work which are 0-5 volts on wide band systems. Buy a normal 3/4 wire heated sensor and that display, and you are good to go.
You can also simply hook your volt meter to the outputs of the sensor and read the 0-1 voltage and know everything that the gauge is telling you.
Steve
Steve
