I have a 1975 Sedan. Should I need to run larger fuel lines? It currently has the stock fuel lines for the stock FI system.
I am planning ot install a 150hp Type IV engine which would later be turbo charged, plus a gas heater (if I can fit it) would be running of the stock fuel lines.
Are the stock big enough?
If not, how the heck to I run new lines through the tunnel without having to slice it open (btw, the body is currently off the pan)
Thanks...MIke
Do I need to run new fuel lines?
Oh yes..the stock fuel lines are plenty large enough. Remember that the fuel injection runs a loop through body, and through it pumps about three times the volume at about 5 times the pressure..that twin carbs require....change to a mechanical or low pressure electronic pump and you should be fine. The gas heater uses very little fuel at all and requires only a receptacle to draw from...as ith as its own metering pump. Ray
- mike75bug
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ray greenwood:
Oh yes..the stock fuel lines are plenty large enough. <HR></BLOCKQUOTE>
Thanks. That saves me a LOT of work
Mike
Mike
