Throttle Postion Sensors
Posted: Tue Apr 03, 2001 1:15 pm
by Tom Notch
Just wondering if anybody knows where there is a bit of knowledge about sensors. Looking for design data like physical size, resistance, direction of rotation, and any other facts about them.
What I need is some specs so I can find one that rotates opposite of the one sample I have off a GM TB. I would like to add one to a TB that doesn't have a TPS on it.
Any clues or leads welcomed.
Tom Notch
Tom's Old VW Home
Posted: Tue Apr 03, 2001 3:36 pm
by Steve Arndt
I have no idea where to look for info.
SDS sells the same TPS but one designed for CCW rotion and one for CW rotation. It might be easiest to just pop the cash for on that works the right direction for your app.
Steven
Posted: Tue Apr 03, 2001 5:21 pm
by Tom Notch
That was the clue I needed. 10 to 1 that their sensors are an off the shelf item and I can get it at my local NAPA store. I just haven't done any research into them at all, I haven't even looked at the one in my bug to see if it is opposite. Just mild musings while at work, but on my break! hehe
Now to return the call from the machine shop, bad news I fear :ekk:
Tom Notch
Tom's Old VW Home
Posted: Wed Apr 04, 2001 6:08 am
by Steve C
Hi
I bought mine from an electronics firm in oz. Its multi directional, you can put it on backwards. My ECU has a calibration function for the TP switch. My system, Autronic SMC calls for a linear or rotary potentiometer, resitance 2000 to 20,000 OHMS, it needs just more than 90 degrees travel, the output voltage to rise with increasing throtle opening.
I will try to get the brand or part number of my TPS.
Regards Steve C
Posted: Thu Apr 05, 2001 12:15 am
by Veepster
hey Steve...
what did that Autronic system cost ya??
thanks!
Peace.............BartG
www.teamgodspeed.com
Posted: Thu Apr 05, 2001 8:03 am
by Steve C
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Veepster:
<B>hey Steve...
thanks!
</B><HR></BLOCKQUOTE>
Hi
It was $1800 aus, about $900 USd. In the US contact
G.T.Performance
Unit C, 5640 Arrow Hwy
Montclair, CA, 91763
Ph: (909) 982 8391
Fax: (909) 982 8397
[email protected]
Gary Teague
Posted: Fri Apr 06, 2001 6:28 pm
by Steve C
Hi Tom
The TPS i used came from RS Components, I think they have outlets worldwide. I cant get hold of the part number at the moment, if you need more info I can get it after Easter, my friend with the catalogue is away until then. It even had the correct shape for the throttle shaft.
Regards Steve C
