throttle butterfly size - l-jet
Posted: Mon Dec 30, 2002 8:05 am
by germansupplyscott
folks,
i have a modified bus motor in my '79 westy with l-jet and i would like to increase the throttle butterfly size slightly. i thought an injected 914 part might work, and i wonder if anyone knows the size of the stock 914 butterfly, for l-jet injection. this part should bolt up to the bus plenum.
scott lyons
Posted: Mon Dec 30, 2002 8:52 am
by Bleyseng
45mm for a 2.0L 914 throttle body. Some of the later bus/vanagon motors have the same size.
Geoff
76 914 2.0L
Posted: Fri Jan 03, 2003 7:03 am
geoff,
thanks. mine is the same size.
scott
Posted: Fri Jan 03, 2003 2:14 pm
by Targa
I will be exchanging the throttle body on my stock 2.0 914 for one that has been ported out to 48mm or so. I suggest you do the same but let a pro do it as there is a trick or so involved in this mod. I am paying $250 plus my throttle body in exchange
Rev it up & Go!
Posted: Fri Jan 03, 2003 2:34 pm
by Bleyseng
I paid $75 to have a 2.0L Throttle body bored out to 50mm. Geez, $250 for what!!!
I noticed only a small amount of difference too. I have yet to take it to a dyno. It is supposed to add about 2-3hp.
Geoff
76 914 2.0L
Posted: Sat Jan 04, 2003 7:46 pm
geoff,
who did this for you?
scott lyons
Posted: Sat Jan 04, 2003 8:41 pm
by Bleyseng
A small shop in Seattle. There is a ad in"Excellence" for big bore throttle bodies too for $125. I talked to that guy but I just happened to mention it to the Seattle shop and they did it for me. Bushed the pivot shaft too, very smooth operation without any slop or vacuum leaks.
Geoff
76 914 2.0L
Posted: Wed Jan 08, 2003 8:25 pm
by Dominic
Geoff,
If I send you a 2.0 throttle body will your shop bore it out and rebush it for $75.00 as well ?
Thanks,
Dominic
Posted: Thu Jan 09, 2003 1:44 pm
by Bleyseng
Try Ed Mazula at
[email protected]
These other guys in Seattle are not really set up for this kind of work, very slowww. My point is to look around $250 is waay too much $$$
Geoff
Posted: Sat Jan 18, 2003 4:57 pm
by Dominic
Originally posted by Bleyseng:
Try Ed Mazula at [email protected]
I called Ed from Bigborethrottlebodies.com, he gets $200.00 to do a 914 throttle body. Too rich for my blood. Though he is a professional and knows what he is doing. I am having mine done by a friend who is a machinist. I'm looking to get a slight increase in performance as well since I have increased the displacement and the valve size on my 2.0 engine.
Posted: Sun Jan 26, 2003 11:25 pm
by Dominic
If anyone is interested, there is a guy selling a 2.0L big bore throttle body on ebay for $159.00 I don't know of the guy or shop so do your own research. Just FYI
