<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by fastfood:
<B>Use a throttle cable from a 72 beetle. It was the longest cable made. It will hook just fine into the stock pedal and all. The return sping that came stock on the D-P carburettor is plenty strong if everything is setup correctly. Make sure the engine is warm, (at least the choke) to get the cable in the correct place when you tighten the barrel nut down.
</B><HR></BLOCKQUOTE>i dont understand when people say to use a 72 throttle cable on a 64. the 64 cable has a ring that goes on a bar on the pedal. there is no way to attach a cable from a 72 to this bar. please staighten me out if i have this concept wrong
throttle cable
throttle cable
ive got a 1600 dual port in a 64 beetle. can someone whos done this kind of thing tell me how they hooked up there throttle cable. i have a 31 pict carb and the return spring on it is not storng enough to return the throttle arm all the way. and there is no room between the carb and fan shroud for the original return spring. besides the fact that a 64 throttl cable is to short. i put an extension on which made it long enough. i just need to solve the return problem
throttle cable
Rice, it's what's for dinner!!! :p
