Swing Axel problem
JW63
Swing Axel problem
Post by JW63 »
On my '63 bug, with the bearing cover off, the left rear axel and bearing can easily be pushed in and out of the axel tube about one-half inch. Does this mean that there is a problem with the axel tube or the snap ring in the differential? The bearing is in good shape and has never been run dry in the 100,000 miles I've put on it. Just occasionally, during the last 20 feet of slowing for a stop sign, it will feel like a rear drum is out-of-round. What should I look for when I tear into it? Thanks.
