Redux box rebuild.
Posted: Tue Sep 24, 2002 5:12 pm
by JC-ATL
I've had a number of bay window buses, venturing into my first split with a '65 Single Cab. My first really major project on this bus is a redux box rebuild. I have everything apart on one of them, except that damn inner bearing on the axle shaft. Any tricks on getting that puppy out of there?
To be clear, I'm talking about the upper one.
Redux box rebuild.
Posted: Tue Sep 24, 2002 6:01 pm
by Pablo
El Cheap-o sliding hammer from Harbor Freight.
Redux box rebuild.
Posted: Wed Sep 25, 2002 5:39 am
by JK
First be sure you have removed the circlip?
I forget if there is one on that bearing.
Then unbolt the tube from the sideplate, pull the flange loose from the sideplate.
Tap the tube assembly off the axle.
Now you can use a piece of pipe through the
tube to tap out the bearing.
If you aren't wanting to remove the axle tubes I think you may need the special puller from Baum tools that grabs in between the balls. That bearing is the standard bearing used on beetles and earlier RGB except the outer top. 6308? 6803? Anyway that tool with that bearing extractor is about $200 so the cheap way is to knock the tube off but there is more labor involved.
Redux box rebuild.
Posted: Thu Sep 26, 2002 8:52 am
by JC-ATL
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Pablo:
El Cheap-o sliding hammer from Harbor Freight.<HR></BLOCKQUOTE>
Thanks! Bought the one from NAPA. Had to modify the hook slightly, but it worked great once I did.
Redux box rebuild.
Posted: Fri Sep 27, 2002 7:29 am
by Pablo
You've got a snug housing, and that's a good sign.
Redux box rebuild.
Posted: Fri Sep 27, 2002 8:11 am
by JC-ATL
That's good to hear, since when I pulled the cover off the first time, one of the bearings came falling out in pieces onto the driveway. Luckily, no gear damage.
Redux box rebuild.
Posted: Fri Sep 27, 2002 11:37 pm
by Pablo
Yikes.
I used to replace these ball bearings with roller bearing equivalents. But it's been many years, but I recall that there was at least one thing to watch out for: the U.S. equivalent is perhaps a half thou (.0005") tighter fit, and should only be installed after polishing the shaft.
Redux box rebuild.
Posted: Mon Sep 30, 2002 9:22 am
by JC-ATL
I didn't have any problem with pressing that on at all, but I also made sure I had German parts, too, which probably helped.
Redux box rebuild.
Posted: Mon Sep 30, 2002 3:13 pm
by JK
Well live and learn! How do you get the crook from the slide hammer into the bearing?
Seems like there wasn't an easy way to do it.
John
Redux box rebuild.
Posted: Tue Oct 01, 2002 5:22 am
by JC-ATL
Well, it wasn't easy. I had to modify the hook a little, grinding the outside corner to a round, and deepening the hook part a little, making what was originally an 'L' shape more like a 'J'. After doing that, I slipped it into the bearing, hook pointing up, and it grabbed onto the inner lip of the outer bearing race. It held pretty well, and from there it was a walk in the park.
