where do i check to make sure it is ok?
undear the van itself 73 bus
Is anybody else having problems with there password?
transmission fluid
- Lavabo
transmission fluid
recent conversation on type 2 list:
yes do change it every 25 years or so!
GL-4 can be found at NAPA, its Sta-Lube brand.
There was NO DEBATE--GL-5 is very, very bad for buses;
I am going to replace my tranny now. . .
(I have heard that the high sulfur content
eats the brass(?) syncros in old VWs).
- Bookwus
transmission fluid
Hiya Muck,
Yep, you have to get down and dirty to check the tranny fluid. Under the bus on the driver side of the transmission you'll find a 17,, plug about halfway up the side of the tranny case. Remove that plug and you should just be able to feel the fluid at the bottom of the plug hole.
I have to agree with Lavabo on the GL-4 vrs GL-5 issue. Although I would say that the NEWER multi-viscosity tranny fluids are supposed to be OK for use in our older transmissions. I'll stick to GL-4, thank you.
