A/c belt part # for bus DPD units
stinkbus
Post by stinkbus »
After an exhausting search, I cross referenced the A/c compressor belt which is no longer available, to a NAPA belt. I have installed this belt and it works perfectly. The Napa belt Number is #7460. It is a 10.5m wide belt and the factory calls for an 11mm.The factory also calls for a 1180mm long belt and the NAPA belt is 1185mm. The NAPA belt's dimensions are very slightly different but it functions just the same and appears to be a much better made belt than the factory belt. Hope this helps anyone.
