What to look for in a bus
Pillow
Post by Pillow »
Window seals are easy IF you know what you are doing.
Look for RUST! Anything else is fairly straight forward.
Adrian Pillow
'66 VW Westfalia - "Biscuit"
'79 Porsche 911 SC - "Cochese"
amoto
Post by amoto »
I'd check the front beam. I thought the one on my 72 was solid until a shock tower ripped off this summer. It had rusted just enough to weaken it. (driving on some bumpy roads) It can be replaced, but it looks like a lot of work.
Robby
Post by Robby »
ease of shifting. My '73 shifts like poop but when I bought it, it was one of those "oh, I can fix that" things. Still haven't gotten around to fixing it but it is a definite pain in the ass. just make sure you can find the gears.
you'll probly want a compression tester too.
That is to say, if there's no rust.
72SuicideRag
Post by 72SuicideRag »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Astron'sGottaBug!:
<B>Should I be able to get a good idea of the floor pans if I crawl around underneath with a flash light, or do i need to look under the carpet. Thanks
ast</B><HR></BLOCKQUOTE>
Hi Ast,
Yes, definately look under the carpets. Especially since you say it's missing some rear glass. I've seen some pretty nasty cargo areas that looked fine from underneath. Check from the inside where the floor meets the sides. Also check under the front carpets at the front foot area. That's a common place for rust problems.
Check behind the front bumper (bottom of nose), also a bad rust area.
If you can see the backside of the nose from the inside, check for any big indents. Bus noses are notorious for getting punched in and I've seen some pretty thick "bondo" jobs to make it look nice on the outside.
Oh, and the area on the outside directly below the windshield.
Good luck!
~~~Steve
'62 Rod Progress Pics http://photos.yahoo.com/volksroddin
'72 Super http://volksrodder.tripod.com/id19.htm
rich2481
Post by rich2481 »
Show up with a magnet , flashlight and a screw driver, let the owner know you are going to poke it in a few places so just in case you hit the rust gold mine they wont get mad. I would look at the battery compartment too, some people dump water into them and the boxes dont last.
