Oil cooler seals problem
Posted: Sat May 04, 2002 11:03 pm
by stinkbus
I have been having some problems with my 79 bus oil cooler seals. I just completed a rebuild of the motor and got it back together. when I start the motor, the oil gushes out of the seals. Could my cooler be clogged? I tried to replaced them and no luck, it still leaks. It's really pouring out too. Any help here guys...
Posted: Sun May 05, 2002 8:56 am
by luckys420
i think the 79 would be the same as a 73.... so i f you put the seals in bacwards this will happen. i think( dont take my word for it) that the small end goes to the cooller. the big and small end of the seal are not very different so try to get a second oppinion on wich side is big and which side is small.
Posted: Tue May 07, 2002 8:13 am
by rich2481
You can check your oil cooler by sticking your finger over one hole, tipping it, and seeing if oil comes out other, makes a nice mess anyway, Make sure your seals are correct,
Posted: Tue May 07, 2002 11:30 pm
by Pillow
Maybe there is a hole in the oil cooler itself?
I have not seen brand new seals leak before if properly installed. They are hard to mess up so I am *assuming* they are correct.
Adrian Pillow
'66 VW Westfalia - "Biscuit"
'67 VW Deluxe Westfakia - "Dino"
'79 Porsche 911 SC - "Cochese"
Posted: Sun May 26, 2002 7:18 am
by Robby
don't sell it Todd. You'll never forgive yourself.
