speeduino android dash app
jpryorx2
Post by jpryorx2 »
i'm running speeduino 202305 and can not get any dash app to work properly on my tablet. real dash will connect but the tach is all over the place. it says it's using the aug 2020 release.shadow dash will connect but does nothing and is asking for the ini file. and ms droid won't even connect. i think i need to have the 202305 ini on my tablet but can't figure out how to download it. if i try to send it from my computer i get an error that the tablet doesn't support that type of file so this might be more of a electronics question. how i built this engine and have it running is beyond me because i am flat out stupid when it comes to modern electronics. can anyone help me thru this setup. i would like an app that shows gps speed ,tach,temp.oil pressure.and afr
thanks
jason
Bruce.m
Re: speeduino android dash app
Post by Bruce.m »
You might want to consider a firmware update. There was some serial comms improvements in a recent release. However it can be tricky updating the firmware, if youve not done it before.
jpryorx2
Post by jpryorx2 »
yeah it's been awhile since i've updated it. one of then if it's running good why screw with it. i will try it this week otherwise my thought is a windows based tablet and just use ts as a dash
