type 4 blow tru
Posted: Sun Sep 22, 2024 10:01 pm
by Lasse DK
hi, has anyone put pressure in a type 4 engine with original low compression pistons. think about how strong they are. the plan is a 2.0 type 4 bus engine, web cam 163 ported 2.0 cylinder heads. 40/44 solex kadron. with blow through. cb black box. and cb ignition. a gerrat turbo from a 2.0 petrol. I have these things on the shelf at the moment. the target is approximately 200hp. it is for my bug pickup with vw T3 bus automatic transmission. what are your thoughts
Re: type 4 blow tru
Posted: Thu Oct 03, 2024 6:33 am
by oprn
I might be the wrong guy to answer but I think a type 4 engine with it's strong bottom end and better cooling heads is the right engine to boost. As for the Kadrons... had a set, not a fan at all, gave them away and bought some genuine Italian Webers. Kadrons are the Chevy Chevette/Ford Escort of the carb world, get the job done if you are short of cash. Quite frankly though if I were building a turbo engine today I would start with EFI and crank trigger for their superior control. Opens up a world of better options for intake air temperature control too.
As for the auto transmission... well, I suppose that is what you have....
type 4 blow tru
Posted: Thu Oct 03, 2024 8:48 am
by Bruce.m
If the boost is very modest. Since you aren’t suggesting an intercooler.
