I just write it up what have been happened in last few weeks.
Engine came down and to parts again because I really wasn´t pleased with that pressure ans sloppy pump fitment. It just made clocking noise when you heat the oil to 90c and let it idle, when it was near 1000 or lower rpm. It blinked betweeb 0.3-0.4 bar (near 5psi)
I regrinded the crank and ordered new bearings. Also replaced all gaskets. Made oil pump to tight fit.
Result is strange. Little improvement on low RPMs but insane peak on 4k (starts at 3.5k already)
compared to last time it was like that:
difference:
5 -> 7 PSI@ 1000
17 -> 19 PSI @ 2000
29 -> 33 PSI @ 3000
43 -> 68 PSI @ 4000
oil was same mobil 5w50 and oil temp was same (near 90c)
As you can see there is massive change on 4k somehow. When it was not warm yet it act not normal also it was 3 vs 1 bar @ 1000rpm in same minute, it floated. Seems like this valve is still making some problems. All I can quess is that valve can make that change on 4k also. Smtng like it sends it all to cooler until that point and somehow my cooler lowers the pressure. Its really big 12 row cooler with electric fan (controlled by ecu) Maybe I can somehow manipulate that spring or coil? I was thinking about making it softer. If I´m not mistaken it moves then more far and it opens ports like it doesnt need cooling and goes it directly to crank. I quess it lowers maximum pressure too because it lets it back to pump suction side more easy. Maybe it can still cool it down somehow. Another option is to switch cooling fan really early to keep it quite cold. On idle it can keep it under 70c if needed, it ads some PSI, not sure how low I can keep on the road. I´m still wondering how I can see such increasment on 4k rpm, what could cause that.
I´m afraid of the pressure on 2 and 3k, on 3.5 its alreadi good (45PSI)
I quess I have to put it together and start tuning it on my dyno. At the moment we have winter temps here and I can give you final result after 6 months.
I´m a bit thinking about removing original oil filter mount and close cooler lines to make it all new with external thermostat.
Here you can see RPM vs pressure (engine temp is oil temp in C)
https://www.youtube.com/shorts/2nv3c618Hrc
