TB's for VW412 or stock carb type4 intake manifold?
Wally
Post by Wally »
I have a stock VW412 1800 engine and those use this stock intake manifold:
The studs have stock Solex 34PICT spacing: 68mm.
Bore is 40mm
What Throttle bodies would fit these the best? Ideally also with a 40mm throat size.
Any ideas what is out there in this size?
Tnx
Walter
Paul H
Re: Throttle bodies for VW412 intake manifold?
Post by Paul H »
Like these ?
I still have them somewhere
viewtopic.php?p=1219477#p1219477
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
Wally
Post by Wally »
Oh yes please! 38mm would be great, but 36mm probably enough as well.
Your 24-1 trigger set-up was behind the original shroud as well?
Its nice (and better) to have 4 injectors, but would just two TB's with 1 injector on each side in the TB be tuneable?
Just seems cool to only have to replace the carbs with two TB's with build-in injector on each side. Seems to me there would be a large bus market for that, especially if the original air filter system could be used.
Tnx for your thoughts guys!
Paul H
Re: TB's for VW412 or stock carb type4 intake manifold?
Post by Paul H »
Quite happy to sell you those throttles for a nominal ( virtually free) amount. I'd throw in the manifolds for free but they are prototype complete with JB weld . Also have quite a few of those cast iron manifolds and a box full of the bare billet throttles
Paul H
Post by Paul H »
yes the 24 trigger wheel is behind the fan although I wouldn't do that on a T4 unless it's an upright cooling conversion as it's just way too much of a job
to fit and or replace . Use a distributor based trigger instead
Wally
Post by Wally »
Cool, dizzy based would be very stealth and an interesting experiment!
I have send you an e-mail, lets do this!
Tnx!
Paul H
Post by Paul H »
The experimenting was done by VW in 1990 ish :wink: It works . Crank trigger was mainly a cost saving by the engine manufacter
