Judder / binding of Porsche calipers - fixed
Bruce.m
Post by Bruce.m »
Just a quick note to add some information that might be useful to someone in the future via a forum search.
I have Porsche boxster calipers front & back on my ballpoint beam standard beetle. Theses are fitted using adapters to convert the axial mounts to radial. The rears use early 944 caliper mounts.
The brakes are excellent in response and balance, using the stock beetle master cylinder.
However after a few hundred miles, I started to get a harsh judder at very low speeds with very light braking. Mostly around walking /running pace. Never at speed.
The noise was slightly alarming and it seemed to cause the brakes to bind. It only happened with light brake pressure and pressing slightly harder stopped it.
Checks on the pads & rotors found nothing.
After a couple of weeks of this, I figured out it was due to slightly play in the front wheel bearings. I had adjusted the bearing spindle nut to stock amount of play using a dial indicator. I had checked and readjusted, again to stock clearance. However I went back & adjusted to “zero preload” setting, by taking out all slack but leaving the washer free enough to move easily using a small screwdriver (the old school adjustment method).
This fixed the problem and the brakes are back to being fantastic.
So when you have multiple piston calipers, they are very sensitive to front bearing adjustment.
DerrickfromNC
Re: Judder / binding of Porsche calipers - fixed
Post by DerrickfromNC »
What master cylinder are you using? I have Porsche 996 calipers & rotors on the front & CB Perf disc brake kit on the rear. I haven’t gotten it on the road yet so I don’t know what kind of pedal feel and braking performance I will get with the VW 21mm MC. EMPI has just come out with a 25mm MC….but a too large MC will result in a hard pedal
Bruce.m
Post by Bruce.m »
DerrickfromNC wrote:What master cylinder are you using? I have Porsche 996 calipers & rotors on the front & CB Perf disc brake kit on the rear. I haven’t gotten it on the road yet so I don’t know what kind of pedal feel and braking performance I will get with the VW 21mm MC. EMPI has just come out with a 25mm MC….but a too large MC will result in a hard pedal
Stock beetle master cylinder.
Kerscher & CSP sold a slightly larger MC (Renault part I think) but with the 996/boxster calipers it is not needed in my opinion.
With my rod-end linked throttle pedal, I can heel/toe because the throttle pedal is higher.
